configure mac-locking ports first-arrival aging
configure mac-locking ports port_list first-arrival aging [enable | disable]
Description
Enables and disables the aging of first-arrival MAC addresses.
Syntax Description
port_list Specifies one or more ports or slots and ports.
enable MAC addresses aged out from the forwarding database are removed from MAC locking.
disable MAC addresses aged out from the forwarding database are not removed from MAC locking.
Default
First-arrival MAC lock aging is disabled by default.
Usage Guidelines
This command does not apply to MAC addresses locked by static locking.
When enabled, first-arrival MAC addresses that are aged out of the forwarding database are removed from the associated port MAC lock. New MAC addresses can be learned until the configured first-arrival limit is reached.
The following command enables first-arrival MAC lock aging on port 2:3:
configure mac-locking ports 2:3 first-arrival aging enable
This command was first available in ExtremeXOS 15.7.1.
Platform Availability
